Does anyone know anything about this brand of headlight? Are they any good? Is installation easy? And, finally, are FJ82 headlights compatible with my 1997 CE?? Thanks in advance!
If it's JDM, it won't serve for places that drive on the right side. Those headlights spray left. What you need are headlights that spray right. You'd best verify them before spending any money.
Kalawang
I would defenatly love to have the JDM spec headlights on my LX (with the yellow integrated fogs)
Mot,
Do you by any chance know if the JDM headlights can be a straight bolt on to any U.S. FZJ without any wire modification?
Mot,
I have a set of JDM HDJ81 headlamps w/fogs available.
Pretty sure you would need to rearange the wires a bit as the JDM inner bulbs (fogs) are meant to come on via a separate switch. The outers are an H4 dual filament set up that does both high and low beam duty.
You can actually remove the fog part of the lamp as it's just a yellow lens that goes in there...
then you could run em as an extra high beam over and above the high beam on the H4 bulb.
I don't know about that, but if true, the difference most go unnoticed on many more vehicles that have JDM headlights. I personally have done two JDM headlight transformations, the first one was on my 95 MKIV Supra (updated to 02 JDM headlights) and on my 92 Integra GSR (One Piece JDM headlights) In both scenarios, the only thing I noticed was the better quality glass and better light bulbs / light brightness.
Mot,
