Since I have been lurking for quite some time I have come across numerous threads complaining about the 80's mpg. A lot of the responses state the obvious like "what do you expect out of a 7 passenger tank?" and so on.
To be a productive member of the Mud community, I took a trip over to CleanMPG, An authoritative source on fuel economy and hypermiling which is a hypermiling site. Sure we're not going to get hybrid type mileage, but those guys are so bent on getting every last mpg they can that I thought we could steal some of the tips.
For example -
Do not accelerate quickly or brake heavily: This reduces fuel economy by as much as 33 percent at highway speeds and 5 percent around town. EPA tests do not account for this kind of vigorous driving.
Underestimating highway speeds - The EPA highway cycle assumes an average speed of 48 mph and a top speed of 60 mph. Many state highway speed limits are set at or above 65 mph. Government data indicates that fuel economy can drop by 17% for modern vehicles that drive at 70 mph instead of 55 mph. Even at 65 mph, fuel economy can drop by nearly 10% compared to driving at 55 mph.
Face-Out: As described. When parked, you want your egress to be as clean as possible. Instead of ICE-On, Reverse, Brake, Drive, pull forward, you pull in to whatever parking lot, area, Face-Out. What it does is eliminate Reverse or any unintended fuel use to spin around. Some can use this technique even from their home with limited or no fuel consumption with a FAS based turn around Face-Out. If your drive allows you are in a FAS coming into your drive, pull into the highest spot, coast back while spinning the car around 180 degrees to a slightly lower spot. You are now Face-Out for your next days or drives egress. Even if you do not FAS, it is best to spin your car around when it is already warmed up than in the morning from dead cold. Your fuel consumption at dead cold is much higher than when warm. Pros, lower fuel consumption. Cons, you have to be careful that someone would not pull in behind and limit your ability to load your trunk. This could increase your MPG by 20% or more.
Of course we can't be hybrids, but I feel we can steal some of these simple techniques that may be overlooked. I for one didn't expect the face out parking to make such a difference.
Comments are always welcome and if anyone spots some other simple things we can do they should post them up.
For example -
over 12,13,14 or 15 mpg is futile. From my experience the best you can do is to just drive easy and enjoy the ride. IMOHO if fuel consumption is a problem then this is not the right vehicle for you. It's just the nature of the beast but the trade off is that you have an exceptional vehicle, one that is unique from any other on the road. Another trade off to the poor milage is a vehicle that doesn't nickel and dime you in the shop. You will always save more money from the shop than at the pumps. That is pretty much the deal with any Toyota truck.
