Mounting RTT to Trailer??
State of Flux...
I'm buying a 5' x 12' utility trailer and fabricating / welding a 4' x 5' raised platform with reinforced expansion metal deck to mount RTT at the front of the trailer. I want to park a 4-wheeler below the deck w/RTT. I'm also converting it to SOA w/33" tires to gain some additional clearance for mild off-road excursions. How should I secure the RTT to the expansion metal deck? Any / all input is appreciated...
Depends on the RTT.
And you'd probably want to secure it to a cross-member rather than to the expanded metal?
Depends on the RTT.
Please elaborate...should I deck the platform with treated plywood and screw to plywood OR other? FYI- it will be a new Mombasa Expedition tent. Thanks
I think that some type of a crossbar system would be better too. Don't think as much along the lines of a floor, as you would a rafter or joist system to hold up the tent. A simple tube rack that was gusseted would be sure light and stable.
Hop into the trailer section and ask a few fellas to post up pics.
You'll love the RTT! :D
if the new Mombasa is like the older ones, there is no need for a floor to mount it to. Just a couple of crossbars will do. And expanded metal mesh (the common kind I'm thinking about at least) is not very strong. I have posted pics of my mounting system here if that helps. OTOH I use a "cover" on the trailer to keep wandering fingers out...
Pics??? Thanks
