Motor has to come up off of the mounts (you can jack it up, use an engine hoist, etc.) and then remove old motor mounts, put new ones in, and then lower engine back onto frame mounts.
Loosen all the mount bolts. Then jack up one side of the engine at a time to swap the mount out. Not a big deal. If nothing is rusted to death you could be done with both mounts in an hour or less
Put the frame up on jack stands. Loosen all the motor mount bolts then use a floor jack and a 2x4 to lift one side of the engine at a time. This is how I've changed older chevy motor mounts, it should work on these as well. Find a good spot on the side of the engine that you can wedge the 2x4 under, where it won't bend/damage anything or slip off. Put the jack under the 2x4. Then slowly jack the engine up just enough so you can swap the mount out. Don't lift the engine too much or you risk damaging wires/hoses. You also have to be very carefull while the engine is lifted so it doesn't slip off the 2x4 or jack, you do not want your hand to be in the wrong place at the wrong time. If I had a cherry picker I would have used that instead but my access to tools/equipment is limited.
