My 1997 LC with just under 100k has a vibration that is pretty felt pretty heavy when you put your hand on the transfer box shifter at moderate speeds, say 40 MPH. I have had Land Rovers before, and some transfer boxes will make a lot of noise/vibration if you pay too much attention, so I have paid little attention up to now. I get a pretty good clunk on throttle off throttle occasionally, not always, and just made a mental note that the mounts must be getting worn. I recently had the contacts in the starter stick, thank you to those here that helped me, and while under the truck checked out the motor mount, trans mount settup and appearance. Seems the trans mount is not likely to fail, but the motor mounts did seem to be a bit collapsed, mostly on the passenger, right, side of the truck. I figured I would check the forum for old posts, that there would be a great deal of information to help me decide what is up. There is hardly anything, besides whether or not to use a polyeurethane replacement. Do these mounts wear out? I have not looked for movement in the engine load/off load with the brakes on, and am really only just trying to make the ride a bit smoother, I know the mount is not torn or broken. Any help?
