Motor mount bolt thread size
Mace
rock scientist..
Staff member
s-Moderator
Moderator
Las Vegas
I cannot for the life of me figure out what the thread pitch and size is for the front motor mounts on my 79.
Either the motor mount is cross threaded bad or it is not conventional fine or coarse thread (Yes I know it is metric :flipoff2: )...
Anyone happen to know?
Poser?
I am about ready to swap out the front motor mounts to a set I have that has two studs. Course, I don't have the nuts to those studs and they are probably some funked up thread pitch too lol
It's a fine thread pitch (fine pitch threads will take more torque), originally they had castle nuts on the bottom, I replaced mine with high grade zinc bolts and used nylon locking nuts. I could not find castle nuts in a metric size at the time I was replacing them and did not want to put any SAE crap on my truck. I did use thread lock but found afer starting it several times the engine "settled in" maybe and retorqued them. The drivers side was a challenge to tighten with the bolt and or nut (can't recall which) is in the frame itself.
I think most of the fine thread pitch used is 1.0 ie M14x1.00, I don't know off the top of my head what size the bolts were. I can tell you they were a royal bitch to remove. I used a cut-off wheel after rounding them and a cold chisel after breaking a nut splitter. Use plenty of heat and penetrating oil and maybe you can get them free, but i think you'll wind up cutting them off. Good luck
They are not conventional fine or coarse thread....
The problem is not getting the bolt out, but rethreading one in..
12mmx1.25x25 is the bolt that holds the cast mount piece to the engine block...
12mmx1.25 is the thread size/pitch for the bolt that attaches the cast piece bolted to the block to the engine mount.
:beer:
I knew you would have this handy steve :D
Thanks amigo..
Just found out yesterday that my ENTIRE DRIVETRAIN is moving back and forth by about 1/2" :eek:
:flipoff2:
so what is a good length? 25mm or 40 mm?
I was thinkin 40 mm
I was thinkin 40 mm
Kind of vague, don’t cha think?
What piece are you looking at retaining to what?
Cast engine mount that attaches to the engine is held on by 25mm long bolts.
The bolts that attach the case piece from the engine to the isolator may be longer, but not by much, probably only 5mm if so.
Well, you gave me the length of the block to mount but not the mount to rubber motor mount thingie ;)
Process of elimination :flipoff2:
Thanks Steve.
