More Window Switch Contact Cleaning
St. Louis, MO
Yes, I've searched and read the threads and I know my slow windows are almost certainly the result of dirt in the tracks. I have new tracks for both front doors on the way (Thanks Dan!). I just figured I would play with cleaning the contacts as others have suggested so I know how much of the problem is due to the tracks and how much (if any) is due to the contacts.
First three pics are my DS master switch contacts before any cleaning. The black is carbon build-up on (and around) the contacts.
The next three pics are post-cleaning.
I used mainly everclear (evaporates quickly without damage to electronic components). I also used a small piece of 120 sandpaper and a Dremel tool with a 180 grit sanding cone (used a lowest rpm setting).
After reinstalling the switch, I tested it with the engine off (key in 'on' position). There was a notable improvement in the speed of the window going down, but no noticeable improvement in the speed of the window going back up.
With the engine running, there was the same or slightly better improvement in the speed of the window going down, and a minor improvement in the speed of the window going up (beyond placebo effect IMHO).
So, it seems I will wait for the parts from CDan as planned.:frown:
A couple of questions though.
(1) The contacts seem to have a checkered or grid pattern. This would seem to decrease the contact area and thereby reduce the electrical transfer across the contact. It would seem then that grinding off the carbon build up and removing the checkering would help (but I was careful not to do this as I figured Mr. T. did this for a reason). Any ideas?
(2) Some of the contacts seem to be 'tinned' or otherwise coated. Why?
(3) Would dielectric grease (or anything else) help prevent future carbon build-up while increasing connectivity?
In the end, it seems to have been a waste of time. But it was only about 1/2 hour even at my snail's pace, and it was a nice afternoon to work on a simple project.
Now for that front axle service . . .
thanks for the info I too have had this prob for a long time and I hate it.
But I don't want to just throw money at it.
Please let us know if the tracks work out.
No personal experience, but: They'll work out.
I always pay close attention to these "slow window" threads when they come up. The folks who go ahead and replace them are always happy with the results.
Simple test: Lube them with WD-40. If that gives you temporary improvement, then new tracks will give you permanent (well, 10 years or so...) improvement.
CJF is definately correct. I only ordered the tracks after searching and reading a ton of post about slow windows. I tried all the lube suggestions and then just ordered them. Since I'm anal, I figured I better test out the switch contacts while waiting for the tracks - just to be certain about any improvements in speed.
Also, I didn't find any good photos of the switch innards, and I was curious just how bad the carbon build-up could be. I figured the pics might be helpful to others in the future.
