1987 FJ60, approx. 160,000 miles, and to my knowledge none of the stuff I'll talk about has been replaced. I have owned it for about 5k miles, so pretty new at the Cruiser game.
Decided to rebuild T-case. Was going to do it in the truck, but after reading many threads it seems like it will be much easier to just pull the case and trans and do the rebuild on a bench. So, I get under there and start to pull things apart. While draining gear oil I notice a metal 'paste'(for lack of a better term) / shavings on both the t-case and trans drain plugs, which I just changed less than 2k miles ago to the allen-style. Pic is of the trans plug. Does this amount of metal warrant a rebuild of the trans too?
Also, noticed a bit of motor oil coming from the rear of the engine. Leaves drips on the driveway. I suspect a rear main seal.
So, if I am already pulling the t-case and trans, how much more involved is it to get to the rear main? How far down the rabbit hole should I go? Replace the clutch too, since that will be removed anyway? Just looking for some input from people who may have done all this before. Thanks in advance!
