I've gone through tons of threads on this but still can't find the problem!?
1994 LC80.
PO (Friend) Went through mud pit about 2 months ago. Caused engine to sputter and throw CEL codes. Cleaned MAF, TB, Intake, cleared code and ran good until last week.
CEL back on again, sputters on idle, as in the RPM is too low to handle the load, its at about 500RPM. If AC is turned on, idle goes up, but still runs rough. Pulled battery terminal to clean just in case and it reset the CEL, so I can't pull the code since its not on, correct?
Once driving, it is OK. Definitely a hesitation on acceleration though.
Until yesterday, idle would be fine when cold, got worse as it heated up. Now this morning its doing it even when cold.
Tested two "big" ports on diagonistics box and got one reading at about .5V, and one that went from .7V to 0V every 2 seconds. Supposidly I am testing the O2 sensors?
Distributor cap, rotor, wires and plugs all changed BEFORE the mud pit incident. Doesn't seem like an ignition problem to me, as much as some sort of sensor or something to keep the idle high enough.
Any direction would be appreciated.
1994 LC80.
