More power steering...
Edmond, OK
Has anyone used the Downey offroad "early model steering colum anchor" kit for powersteering conversion.
I have one on the way and would like to hear from someone that has used it.
Jody.
Did you consider possibly utilizing the newer style anchor?
Just wondering how much would be involved to adapt column to the newer anchor...
manny 72fj40
I asked downey about a year ago if the newer anchor would work on my '70 FJ40 and they said it would not. I haven't ordered the kit yet
I have a 70 fj40 and I just swapped in a newer (75?) column along with that tractor bearing shown when I did my convertion. Was a peice of cake, just made a stencil out of cardboard of the hole I needed to cut. Cut it, drilled a few holes, mounted it up.
What did you do about the ignition switch and turn signals???? Did you rewire them into the new column wiring??
I think the tech section here lists the bearing style mount that downey sells and it is like $15 instead of $60. Check that out before you use the Downey part, might save some dough and it is a better setup.
I got suckered into using the downey kit with the expensive bearing, those guys are a rip off, good quality stuff but too much money. I am not familiar with older style steering columns, is there an issue with the mounting of the column to the firewall?
