More PO electrical oddities question
Seattle
This was connected to ground on the carb fan. One wire colored light blue with a black strip and one wire green connector.
Is this supposed to be a ground? Or what is it supposed to go to?? Been trying tind it in the wiring diagram, and I think I'm perpetually crosseyed at this point!
My 78 ewd shows a L-B wire from the cooling fan timer to the manifold thermo sensor. Could that be the wire?
I found an LB wire coming from the emission control computer to VSV #3. My rig is desmogged, is this wire even needed?
Only other LB wire I found was to the front and rear blower motors.
That VSV wire shouldn't be long enough to reach the carb and should be part of a multi-pin plug.
Does your carb cooling fan work as designed?
There is another LB wire here:
Ok, I discovered the errant LB wire does not go to the computer, and happened to look under the manifold to find what I believe is the temp sensor for the cooling fan! So, I think that's it!
I don't know if the one in my rig even works. Anyone know if there is a suitable replacement?
Thanks!
Replacement for the fan or controller? No replacements, except used.
Thanks!
SOR used to have replacements. They are no longer available, as far as I know. Something can be substituted. I believe the actuation temp was 174 degrees, so you need to find a temp switch with an actuation point in that vicinity.
