Howdy, I have read exhaustively about these things on this board and elsewhere, but a couple questions still remain. First off I have a 1994 with 156k, recall was done in 1996. My rig has been throwing occasional code 28s, so I ran through the FSM tests several times and found that both sensors are within specs and are functioning correctly.
I don't know if they have been replaced since the recall, but according to the tests, they operate withing specs. The heater resistance is right at the upper end of the scale --6.4 ohms with 6.5 allowed.
The sensor cycle is well above min spec--Mine cycles 13-14 times per 10 seconds, while the FSM allows the cycle to be as slow as 8 per 10 second interval
According to the flow chart in the FSM, everything checks out as normal, but I still have an intermittent CEL with no pattern--1st time was a hard pull on a hot day, second time was easy highway driving early in the morning, then it shut off by itself and came back on a few days later during city driving.
So, Do I spend 200 bucks to replace sensors that by factory tests are in good shape, or do I look elsewhere?
Also, is it worth while to clean these things? I was all set to try that today, but after looking at it, I don't want to have to do it twice.....
Thanks,
Dan
Thanks,
Dan
