- Joined
- Dec 24, 2003
- Threads
- 136
- Messages
- 3,559
Wow, like the proverbial candy store ...
I've been playing and playing with this OBD super scanner and trying to learn as much as possible about what all this real time data is doing for me. One thing that is interesting is the comparison between what the stock coolant temperature sensor is showing and what the aftermarket coolant temperature sensor is showing.
I expected there to be a big difference between the two sensors in that the aftermarket coolant temperature sensor is located inline on the upper radiator hose, after the discharge from the block, the head, and the turbo ... and also in that I actually anticipated that the stock coolant temperature sensor would be as accurate as the stock coolant temperature gauge (ie not at all accurate).
I was super surprised to see that the stock sensor (not the stock gauge) is actually amazingly accurate and also that the turbo only adds an additional 2 to 4 degrees Farenheit to the system even when humping really hard!!! I measured several different things several different ways - first the coolant temp in the rad, the rad overflow, and the upper radiator hose after the vehicle had sat still overnight on a combination of relatively cold nights ( 30 degrees up to about 45 degrees ... I wont leave the rig out when it is below 30 degrees) and then on a combination of relatively warm nights in my garage ( 60 degrees up to about 70 degrees ... garage is heated to house temp). Then I measured the stock and the aftermarket sensors in a very wide variety of operating conditions.
All my data thus far confirms for sure that the stock sensor (again, not the stock guage) is actually super accurate, that the turbo only adds an additional few degrees, and that whether a person is measuring off the stock location or off the aftermarket location, their data will be basically accurate. So options for my fellow mudders: 1. Get an aftermarket gauge like mine and call it good. or 2. Get an OBD port scanner and scan all this data without worrying about even installing another gauge. I know that Greddy makes a cool interface called the Greddy Intelligent Informeter that costs approx $300 and with this you can scan six separate lines off of the OBD port. Anyways, HTH, Thanks.
