- Joined
- Mar 27, 2003
- Threads
- 70
- Messages
- 1,059
Yes, I realize that an autotuning antenna is really sub-optimal, but I think it should serve me for the majority of my mobile needs. My plan is to make a few diploes or long wire with tuner for home and 'up north' where I can run a real loooooonnnnngggggg wire!
A few questions on the HF antenna position and RF grounding. How far down the hatch have you been able to mount the antenna and still open the hatch? Is your groudning plan to ground to the hinge and then continue to run a strap down to the frame? I'm also wondering if I need to run additional ground straps from the muffler to frame, etc?
My plan is to run the box to the back of the truck. I will either mount it low down on my cargo barrier or in one of the side locations (which would make it harder to remove for home use).
I also plan to use the PowerPole connections so I can quickly swap the unit from the truck to home to 'up north' to battery operation etc. So I will need to do is unplug the power and antennas and I'm off.
I plan to take advantage of running a line for the remote operating mike and a mobile speaker. Did you run an external speaker - where is it and what kind?
With all the operators coming on board I think it's high time that we do a trial 2M IRLP IH8MUD net!
Cheers, Hugh
Cheers, Hugh
