More center cap refinish tips
Just refinished 12 center caps this evening. Did my 93's caps for the 2nd time in 14 years, the 97's for the first time, and my bro in law's 93 with 320,000 miles on it for the 1st time. Can no longer get the Plasti-Kote paint I used last time so I went with the Dupli Color Platinum others have used. Got their Adhesive Enhancer as well as their grey primer and clearcoat for a total of 4 different paint layers. Nothing new there - others did the same. Thanks for the tips.
However, I tried a stripping agent for the first time and used Klean Strip's Peeler FS-459 with excellent results. It's an 18oz aerosol and I have some left over after stripping 8 caps (more on other 4 in a minute). You spray it on, then use rags to wipe the paint off. Took about 10 minutes per cap, including the 4 minutes of waiting for it to work. It worked extremely well on the factory painted 97 caps, but the larger quantity of paint I put on the 93's last time took more work simply because of the layers. It's designed to strip paint off plastic automobile bumpers without harming the plastic. I got it at an automobile body shop supplier in town.
On my brother in law's, I did them secretly so wanted to preserve the original black centers. So I just sanded the peeling silver. Found that those cheap plastic cups restaurants give children were the perfect size to cover the black center when it came time to spray. You just set it on the cap and the cup's rim fits snugly down into the center, spray, move the cup to the next cap and so on. So his silver looks like new and the black was actually in perfect shape.
So, I've got 12 caps drying on the kitchen table to be installed in the morning.
DougM
12 caps.
Strong work.
I thought my 6 caps was a record (one for the spare and one to replace one I lost).
Good find on the plastic cup mask. I did all mine silver, then carefully masked, the black. The cup sounds slick.
DougM
Well, by now you should know how I am with my pics - heh. I can't even figger out how to put up an avatar! No pics, but the 8 for my truck turned out really beautiful. The BIL's ones not as well because I couldn't just strip them since the black needed to stay. But yes, the cup thing was truly amazing. These particular cups came from the Rum Runner restaurant in a back bay of Florida near Ft. Meyers Beach but they look the same size as others in our cabinet. The kids like to collect them when we travel. They're one short, now...heh.
DougM
Can we get a part number on the plastic cup?
This should be a sticky.
Dupli-color Platinum eh? Mine are in desperate need. I figured I would leave them on until I lose one, and then remove the rest...
On thing I did was coat the gold inlay with bathroom caulk. Once the pait was dry and the caulk was removed they looked like brand new.
I tried to hook you all up on the paint stripper years ago, but for some reason YOU people insist on sanding for hours and STILL not getting all of the old stuff off. Stipper's the way to go :flipoff2:
Having said that, mine went through the heavy duty car washer this weekend and the wheel scrubber FUBAR'ed two of my caps... so :flipoff2: to me.
:beer:
Rookie2
I'd have to say I was skeptical of Rookie2's comments on the stripper. Mainly because over the years I've tried strippers a couple times (boats, etc) and found them to be a ridiculous waste of time and a huge mess. Not so in this case. Be methodical and this is a big time saver. The first one is a learning curve, then the others go quick. I did 8 caps to bare plastic in less than 90 minutes, no sanding mess, sore fingers or sanding marks in the plastic requiring progressively finer sandpaper to fix. With such a complex shape, getting it to plastic with sandpaper would be rough.
With no sanding dust, I also was able to simply blow dry them dry (you rinse/wipe under running water to finish the process) and start painting minutes later. Got them all done in about 2.5 hours. They should last longer than the factory paint with the special adhesive enhancer, primer, clearcoat and modern paint technology.
DougM
