OK, just wanna see if I installed everything correctly. I replaced the guts yesterday and while putting it back together I greased the hell out of every part and before I put the cap on I loaded it with more grease. I put the cap on and used the grease gun on it to fill it up. I put the linkage back on and drove it around the block, considerable difference, next the tie rod ends. but, How long should I drive it until I check the adjustment again. I figure with all the grease I put in there , there must be some voids in it and it would take a bit to settle.
Thanks
Kevin
Thanks
Kevin
