More CB antenna questions...
South Jordan, UT
Making a CB radio plan.
I'm going to mount a Cobra 18 WX ST II below my single DIN CD receiver.
My intended use is communication on trail-runs.
I've read several posts about CB antenna locations, but I'm still not sure what will be the best solution for me. I'd like the antenna setup to be as simple and no-hassle as possible, as well as durable and reliable--but I'm not sure about the transmit/receive tradeoffs made with various locations.
1. I've got a Slee rear bumper/tire carrier with a spot to mount an antenna. I assume some kind of fiberglass whip would mount there. Seems like this spot would be simple to use and have the fewest clearance issues. I also understand that this location may result in the worst reception. How bad is "bad?"
2. I've read that the middle of the roof is the best spot for reception, and I know several people are using magnetic mount Wilson antennas in this location. With 5' of antenna sticking up from the top of your 80, how often do you encounter problems with clearance? I'd hate to mangle an expensive antenna.
3. My factory AM/FM antenna has been busted off since the day I bought my 80. Would it be worth trying to permanently mount a CB antenna in this location?
4. Other options/recommendations?
Thanks for your time.
Hayes
The bigger your ground-plane, the better the signal.
My 0.02 s that you will get pretty much the same range with a mag-mount antenna on the hood (centred between left and right and back at the rear edge of the hood) than with a roof mount. Espacially with an 80, where the hood is bigger than World War Two.
It's a little more protected there, and is quickly removed.
I just attach my antennas to the rear bumpers now. The kinds of trails we have up here aren't very antenna-friendly. Behind the truck is safest for the antenna (unless you wheel in reverse!). Since I'm never more than a mile or two from other trucks I wheel with, I'm not a stickler for range.
