More ARB Carnage
The Saratoga slums, CA
I wish I could say that I did this while attempting some insane line at the Hammers.
The truth is my rear ARB let go while puttin' along on a residential street about a mile from my house. I was just heading to work when I heard a small pop, followed by a very load Bang!, CLUNK, CLUNK, CLUNK. I immediately got off the accelerator, pulled it out of gear and coasted over to the side of the road.
As soon as I jumped out I could see the Exxon Valdez trail of 90wt streaming from the center of the road toward my rear axle. I knew it wasn't good. I ran around the corner to the neighborhood grocery store to buy a hazrdous waste cleanup kit (kitty litter, dust pan & broom, simple green) and cleaned up after myself while morning commute traffic looked on.
This weekend I tore into the diff. Everything is trashed including the ring and pinion. It looks like either the spider gear shaft or the ARB housing itself let go first. The cross shaft was still intact and in place. I've had this ARB in place since '92 and it's seen almost 180K miles. It doesn't surprise me that it fatiqued to the point of failure, but it still pisses me off! I last had the diff open about a year ago and checked all of the retaining bolts. One or more may have backed out but I doubt it.
In addition to the rear diff I think I may have taken out the output shaft of the transfer case. I removed the rear shaft and tried to run on the front end but I couldn't get power to the front shaft. I haven't torn into the tcase yet, but it doesn't look good.
Punched two holes in the cover.
Spider gear wedged into the c-clip window:
Guts that dropped out...
ARB carrier split all the way around.
No Rubithon for me this year :( :mad:
Dang dude! Hate to see an RD08 let go like that since I'm a diehard ARB fan.
Are any of the internals salvageable? Give Tim Lund a call at ARB & see what he may be able to do for you. The most common problem is when the bolt that holds the crosspin shears & the crosspin walks out, but you've already confirmed that didn't happen. So, the axleshafts held up & aren't twisted?
Hi All:
Yikes!
Yeah, give Tim Lund, the ARB Tech Guy a call - he can help you out.
Good luck with the diff!
Regards,
Alan
Seattle
Ouch!!!
Craig, I still have the spare transfer case output shaft I got from you from the last pmc swap meet, let me know if you need it.
/td
That is the second one in a month that I have seen do that. A buddy just had the same thing happen, without the holes in the cover. Going 15 MPH, unlocked, 1/2 mile from his house.
Took out the 4:88's as well.
I know a ton of people who have ARB's, all love them, but these $1200 boo boo's (including ring/pinion/locker/setup) make lunchbox lockers seem more appealing.
Man 180,000 Miles and 13 Years is awesome.
I say buy another one and have another worry free decade at least.
mustardfj40 said:
Ouch!!!
/td
Thanks Tien
I'll keep that in mind. It may be a while before I get a chance to pull the t-case to check it out. I have a newborn at home and I can't seem to get anything accomplished anymore. I usually only have 20 minute blocks of time to work on stuff nowadays.
If the t-case is trashed I might look into replacing the rear with a Dana 60 or 14 bolt and going with a centered output transfer case. Since I need to replace the ring and pinion and locker, now would be the time to do the swap. Since I have the Toybox, it would be pretty simple to replace the transfer case with a 23 spline mini truck case or even a split case if I find an offset axle.
Anyone have a 35 spline, passenger offset, 6 lug, disk brake, Dana 60 laying around that they want to get rid of? :)
