moonroof wont work
Do you get a click from the switch area when you try to slide it open? If so, I might have an answer, quoted from my thread: "As for my sunroof not sliding open, I figured that out. Turns out one of the little screws that holds the tracks in place was missing, specifically the front one on one side. So when it tried to open, it would rack the assembly one way, and bind. I just removed a screw from farther back on the track, and put it in this front hole. I will get another screw later. Works great now. Oh, and the relay would click when you pressed “open”, so I originally thought something was wrong with the relay or switch."
moonroof
well that was a good try, but no clicking noises here, just a dead moonroof, no noise no nothing, bad fuse perhaps, bad switch, any clues folks thanks alot:)
