Monstaliner...How heavy is it?
once i get my 80 i want to do some minor stuff to get it all dialed in but one thing i wanted to do was liner the whole body with montaline,line,rhino line, what ever seems to be best but everyone tells me it is a very heavy material. now weight equals worst gas mpg, not that I'm that concerned with that driving a trail rig 80 around, but i want to know if its a huge difference or unnoticeable. also what kind of protection can i expect? i know its pretty solid stuff. thanks!
Look at the shipping weight. I'd say it's ~25lbs MAX to do your whole rig. Seriously, it won't change your already s***ty MPG's.
I've only read of 1 person on here having a problem w/the Monstaliner & 100's, if not 1,000's, that are happy w/it. It's what I used, & would use again. It dries rock hard, cleans surprisingly easy, great texture, UV stable for years & minimal prep required. I used to spray bedliners, & have used several DIY, so I speak from experience.
Raptor liner worked great!
I've done Herculiner, Raptorliner, and Monstaliner on my last three 80 series rigs.
Herculiner:
Raptorliner:
Monstaliner:
I vote Monstaliner. Herculiner was the least smooth, if that means anything, but I bought it at the store and had it on in a few hours. The Raptorliner and Monstaliner both need to be mixed. Slight nudge to Monstaliner for supporting mud (at least they used to) and great customer service.
I bought the Raptorliner from a paint store in town. Had to order the Monstaliner, but it came with everything I needed.
My advice if you're rolling (regardless of product): change your roller early and often, don't wait for it to be "done" and breaking off into the liner. Extra rollers are worth it.
And as to weight... you will probably not notice on your doors, but I definitely noticed it on my hood.
The cans don't really feel much heavier than normal paint in the same size container. I used it on a trailer and probably won't use it again. Texture is nice, cleaning when dirty is nice but it seems to chip pretty easily kind of like a candy shell. I used an etching primer prior to install but it still chips pretty easy. I know a lot of people swear by it but that's been my experience with it.
tommy.webp I can assure you one thing @Hunter Christian, it weighs a good bit more than Tom Brady's footballs. You can take that to the bank bro!
On another note, I have used Herculiner and found it holds mud, the Monsta like smoother and like the finish guys on here have posted. I still like AL's liner too.....
:rolleyes::rolleyes::cheers:
Why did you use primer first, bare metal? What chemical did you use to clean the surface prior to applying the liner?
Yeah, It was bare metal. New build. Talked with the guys at monsta and they recommended priming first. If just going over a painted surface then scuffing the paint, cleaning and coating is acceptable but from bare steel they recommended their primer or a good etching primer like i went with. I used some MEK and then some industrial solvent to get rid of all the oils and leave the surface clean and dry. The primer adhered great and does not chip off, Just the liner. The majority seem to really like it and the guys that sell it were great to deal with. It just didn't work out for me personally as a repeat product. I still have an unopened gallon waiting to go to a new home.
Not trying to take anything away from the vendor selling it. It came highly recommended and had top notch customer service.
maybe see how many samples you can get to compare and find the one you like the best. I know among my friends we all found different ones we liked. In the end you want to be happy with the investment. Removing to redo is no fun at all.
View attachment 1131937 I can assure you one thing @Hunter Christian, it weighs a good bit more than Tom Brady's footballs. You can take that to the bank bro!
Hahaha I laughed pretty hard at that ahah. Probably because in a few jacks and cokes in but that's beside the point. Thanks for all the advise. I guess when the time comes i wi just take a swing at it and hope for the best! It's trail rig. Not to worried about appearance. Just protecting what I can [emoji106]
one other concern i had was if i montalined my 80 in white would it turn yellow.. i hear white can go to yellow pretty quick. i wouldn't mind maybe doing a grey or army green or tan but white would be my pref.
My truck when running right doesn't care about weight. Seems to always seems get 13mpg whether towing, empty, whatever.
Raptorliner
Raptorliner
Lucky. I've never got 13!!! Average about 10.8mpg.
As far as white goes, it shouldn't turn yellow. There's guys here that have done white awhile back. Maybe one of them will chime in.
Yeah that would be nice. I'd like to see how white over time has turned out. Cause I know this stuff probably doesn't last forever but if the white goes bad too soon I'm sure getting this stuff off and redoing it isn't going to be fun at all
