modifications for moving to Alaska COLD!!!!
Hello All,
Greetings from the land of heat and sandstorms (IRAQ). I just recentely found out I am moving to Alaska In Jan 07 could any of you all give me some advice on what I need to get on my Cruiser to survive the harsh winter there? I sure would love to here any and all advise since I have never been there before! Hope you all are doing good, I have about 60 days or so left here in Iraq so I cnat wait to get home to my family and my cruiser. Take care Tom.
Welcome,
Glad to hear you are coming home! Anywhere is better than being in the land of heat and sandstorms.
Since I live in California, I have no good advice except using more antifreeze than water in your ratio.
The canuck diesel guys use a coolant circulator that fits in the lower rad hose--might help you. Sorry I forgot the name of it but some searching in the diesel board may turn it up. Or just post over there--there's a lot of cold weather knowledge.
HTH
B
You may want to send a PM to "Mark W" here on Mud. He owns a cruiser shop in Wasilla, AK and has extensive experience in what works to keep cruisers running in the cold. He also runs and organizes the annual Aalska Cruiser Trek and I believe he is a technical editor for Toyota Trails (TLCA) magazine.
I spent most of my life in Montana and Dutch Harbor Alaska. These things below I would say are a must for an older vehicle. Get the following: 1. Battery heater-it is a pad that goes under your batttery, you plug it in, it keeps it warm enough to fire your rig up. 2. Inline-water heater- hooks up into your heater hose, and circulates the antifreeze through the cooling system. Keeps it around 45 F or so, pays for itself first time you go to your frozen truck, get in, and fire it up. Windows thaw in about 5 minutes, and your truck starts to warm almost instantly. 3. Block heater-goes in your one of your freeze plug holes. you plug it in, it keeps it warm enough to fire your rig up. ??? I also heard that somebody makes a blanket that you can wrap your motor up in and it also plugs in and warms it up. 4. Keep stock in HEAT. Yellow can, fuel additive in every gas tank. Fuel will gel up. Trust me, you will not believe how cold it gets up there. I had my tires of my 1976 F-150 4x4 FREEZE to the ground!!!
Just my thoughts. If it were me, that is what I would do. Or, just let me watch your FJ while youre up there, I dont think you could EVER find a use for it in AK! hah hah Dude I am jealous. Have fun.
I can sell ya a rear heater too when I take mine out :grinpimp: You're gonna need all the cab heat you can get. I would definitly second the block heater...my grandpa's chev diesel silverado needs one in the winter and he only lives in Carson City, NV so needless to say it isn't half as cold there as Alaska :cheers: Glad to hear you're comin home
I'm in whitehorse, YT (canada), similar climate to alaska (fawkin' cold!) and I have three plugins on the cruiser, recirculating coolant heater (mentioned already) battery jacket heater (mentioned already), and most importantly, oil pan heater, it's a little silicone pad you stick to the bottom of your oil pan, emits 100 or 150 watts, and makes your engine live a longer and happier life. normal mounting is to smear high heat silicone all over it, duct tape it to the bottom of the oilpan, and by the time the tape falls of, the silicone has set.
the other problem you'll run into is that when it's really cold, the rubber insulation on the cords will shatter if flexed, what I did was to mount a junction box (110v household type) under the hood, marrette all the heaters into it, with a nice long heavy duty cold weather wire coming from it, which gives you just one cord to plug in, and easy replacement of the final cord, if you trip on it or attempt to drive away without unplugging (it's happened :D)
might seem like too much info, but i've been up here for four years so far, and this is the resul of my trial and error
Alaskas fun! Run boggers year round and wear a thick jacket! FBX gets colder than down this way, I'm picking up a flexalite mojave heater to stick under the seat this winter. Check out www.ArcticOffroad.com
Good luck in Fairbanks, that place is flipping freezing! Battery blanket, block heater, thin oil, and you will be good.
I lived in the Anchorage area for 4 years and there were only a few days in the winter that I had problems getting the 40 started, but the temps there in the winter are milder than Fairbanks.
If you like cold dark winters, you'll like ALaska. Too cold for my old bones!
