Model F
A while back a bought a NOS F block from SOR to rebuild my engine. It came stamped only with an F. Based on the descriptions above, it is an F145 block. I don't know which F head I have but I have many 2F parts on the engine.
Leon...
Or find a good used 2F engine around, little more power, coupled to the stock three speed transfer case you will have better low gearing. A used 2F complete or nearly so, and the matching 4 Speed tranny would be a very easy swap.
The engine mounts are identical, the bellhousings will all interchange, you can get the proper driveshafts to swap over to the 4speed tranny, or whatever. If it still has the 3 speed, then swapping in a 2F will not alter a thing drivetrain wise. You can even swap over your accesories so the Alternator is in the right spot an all.
Found the following. Is this an easy swap? Any thoughts?
Have a running 87 FJ60. can sell you the complete engine with power steering pump (works, doesn't leak) for $575. Engine has 121K, starts great and runs fine. No bad smoke, it's quiet, and will come complete from pan to air cleaner- including alternator, water pump, fan and fan clutch, exhaust manifold, oil cooler, distributor, gear drive starter, clutch and bellhousing. This engine is in great sghape and is indeed a drop in, the carb even behaves well.
That wouldn't be a bad swap. The 2F engines in the FJ-60's which were 1980 -87or88??? are very good engines, they were improved slightly over the previous 2F engine design.
If you keep your three spped tranny, you will have to swap the bellhousings. If you want to swap to a 4speed, this requires a 4speed bellhousing from an earlier 2F engine, 75-78 I think would work.
If you look on your engine now, the bellhousing has two bolt on mounts on each side that mounts the engien to the frame. On the FJ-60's, or this engine you are looking at, the mounts were removed and a cross member was placed under the tranny like most modern vehicles to hold that end of the engine.
So in summary, if you keep your tranny, which means no driveshaft mods. You just switch out the bellhousing. The flywheel and clutch will have to be removed to take the bellhousing off, there are bolts behind the flywheel.
The starter from the newer engine will swap over, and the clutch stuff will also. I believe you can run either your 1F flywheel and clutch or the 2F flywheel and clutch, you cannot mix them up. You will also have to run the clutch fork from the newer engine in your older bellhousing with the newer clutch if you go this route, but it is all dowable, all bolt in swap basically.
Others know far more about this than me, but I think this would be a good swap if you don't care about the originality of the vehicle, but keeping a Toyota six in it is a good idea.
You will also have some issues with the fan clearing the stock fan shroud, it will take some tinkering. You can also swap over your alternator and bracket, and take off all the extra engine accesories for your 40, unless you want to go with power steering and stuff, then you are ready to go. This newer engine will come with the alternator on the wrong side of the engine to meet your wires for an F. Not a big deal though.
Thanks so much for the info, MoCoNative, I like this route much better than the V8 swap I was looking at doing originally.
