Just received my new longfield super set and was wondering if I need to remove what I think is dino grease that came packed into the joints? I re-installed my turnion bearings with Mobile 1 synthetic grease while I was waiting for my parts? My plan was to use synthetic and I did not think about how the parts would come! I'm pretty sure I will remove the dino grease from the joints befor installation but thought I would ask the question anyway! THANKS
You could call the company in the morning to find out what type of grease the Longfields were packed with and why they use that particular grease?? Ie: no particular reason, or, what they recommend due to some particular property(s) that grease may possess?? You might want to ask the manufacturer/name of the grease, and get the product number, then search for it's specs, or call that company's tech line, if you are curious. I would expect that the proper grease is being used however. The FSM calls for Moly fortified NLGI 2 grease, but it does not specify what % Moly should be used. You should not use the Mobil 1 synthetic grease when packing the Birfs (if that was your plan); it does not contain any Moly. Molybdenum disulfide - Wikipedia, the free encyclopedia
Most off-the-shelf Moly fortified greases only contain 1 to 1 1/2% Moly, like Valvoline's Synpower. Valvoline also makes a non-synthetic Palladium which is 3% Moly. Mobil also carries an industrial line of Moly greases; very hard to find however. NAPA carries the Valvoline Palladium 3% Moly grease, but be sure to check the date on the tube; small stores do not sell a lot of it. Amsoil makes a synthetic Heavy Duty NLGI 2 Moly fortified grease.
You asked about mixing greases; it is generally OK as long as they are the same type ie: Lithium base. Synthetic and Dino Lithium base greases will mix, but may have slightly different characteristics, depending on manufacturer, etc.
Some mudders who have used Longfields; they may chime in later so check back.
