Missing O2 sensor
S.A., Texas
I purchased a '97 80 series a couple of years ago, in pretty deplorable shape other than mechanically it seemed pretty sound. After purchase, upon further inspection I noticed that the cat had been removed and replaced with straight pipe along with the front O2 sensor, only one remaining is the rear one and the only noticeable problem is that it seems to run pretty rich and burn a little more fuel than my other 80, been using as a daily driver the entire time and no cel. Question is when I replace exhaust system should I reintroduce a cat with the front sensor? Would it improve mileage a bit? What system if yes? I'm in South Texas, so no cat required at this time.
The front O2 sensor (upstream) is supposed to do all the work (more or less).
Pretty sure your computer wants to see it plugged in.
The rear (downstream) is there to see if the cats are doing their job.
You may be running in limp or open loop mode with the "main" O2 missing?
How should it run in limp mode? I have no noticeable miss and it actually accelerates better than my other 80. Is there a way to bypass front O2 or trick it, maybe PO had already done this, where do I start looking?
Well, yeah...that's the thing. When in "limp" or "open loop" mode the computer will default to running richer.
Running leaner is worse for the motor.
Normally there is a resistor added to the O2 sensor wiring itself, at the sensor to trick it.
Look and see if there is an O2 plug dangling in the front (before the 1st cat area).
Another thing to get is an Ultragauge:
UltraGauge OBDII Scan tool and Information Center
If you note the pic of the Ultragauge, you will see a little "heartbeat" icon that blinks to show ECU and Ultragauge is running, then on the right side you see a partial circle. The partial circle in that pic shows the ECU is in "open loop" mode.
When the circle is full...you are in "closed loop" mode and the vehicle ECU is working to fully control the engine based on all it's sensor inputs.
If your computer does not detect a front main O2 sensor, it may be running it's "default program".
Basically, "open loop", not listening to engine sensors fully.
Not efficient at all. Sucking tons of gas long term.
Cool I'll check it, damn glad there's smart guys on here!
I can rebuild knuckles with the best of 'em, but the electronics kicks my ass!
