Missing and stalling 4.2VX TD
Hi all
Oh dear! My 80 series diesel has had an exceedingly funny turn today in Turkey. After being parked for 5 days in Gaziantep it started first time and, as if tempting fate, I even remarked on this. About 50 kms down the road it started missing, gradually at first then getting worse, until finally it cut out. After coasting to a halt I started it again, but it would only run if I revved it - it wouldn't idle. I have done nearly 20,000kms on Tunisian, Libyan, Egyptian, Jordanian and Syrian diesel since the fuel filter
was last changed in January so I thought the missing and inability to run at idle was the clogged fuel filter. I changed the filter on the spot but it still wouldn't run unless I revved it.
Just then 2 Turkish chaps stopped by. They loosened the nut on the pipe leading to the no 1 injector and discovered air bubbles galore in the diesel - this was the same for all the other injectors too.
So, I drove on to the nearest garage and had it checked out. The mechanic tightened the new fuel filter, sucked on all the fuel pipes and checked all the unions on the fuel lines and leading into the injector pump. He then undid the nut on the pipe leading to the injectors again and this time there were no bubbles.
BUT - the running was still just as bad as before. I think by this time the mechanic was a bit stumped and as a get me home measure he increased the fuel mixture, and also the idling speed to about 1300 rpm. Now the car won't start unless I floor the accelerator and it alternates between conking out unless I keep pressing the pedal or running OK at 1300 rpm for about a minute before then conking out. It also erratically surges, slows down, misses while it's cruising and generally acts like there's something out of the film 'Gremlins' lurking under the bonnet. If I'm lucky enough to get it moving without it conking out as soon as I put it in drive, I can get it up to about 50 mph and then take my foot off the accelerator - it seems to hold itself at about 2000 rpm in top gear and then if I put it in neutral it will surge to 3500 rpm before slowing down and conking out.
The mechanic said he thought poor quality Syrian diesel was the reason for the problem - however I had done about 130 kms faultlessly on the tank of Syrian diesel I filled up with immediately before crossing the border into Turkey; if poor diesel had caused the problem it would have manifested itself after 2 kms. Moreover tonight's replacement tankful of best quality Turkish diesel has made no difference whatsoever.
The poor car is an absolute pig to drive and I need advice!
Thanks in advance
Mark
Hi Mark
good luck with all of the troubles.
You might want to repost this in the Diesel Tech section, you'll probably find more folks knowledgeable about Diesel engines there, we are not so much blessed with these options with the US 80s...
