Miss Fire #4 code??
Vancouver BC
Hi, I have a 97 lx 450, 1FZ-FE, 289Kl, The trouble started when I washed the engine bay (running) - the truck has problems excelerating off te line (legging or missfire) then I replaced the plugs, wires, cap, rotor and coil. Nothing.. So put the truck in a break stand to see the area of missfire. 1400rpm - 1800rpm when hot. The truck wont miss as bad when its cold. Then I took it to the dealer to plug it in. The code came up for miss fire in #4, we then went real time and it showed the same under load. I have an odd sound comming for the header at the 4th, would this be a bent valve stem or broken spring?? So I did a compression test and number for varied from 90psi to 140psi. Other than putting in the shop I am out of ideas??
OK, so first of all, after you hosed off the engine, did you remove the distributor cap and dry it out?
99% chance of getting water into a stock distributor when you wash things off in there.
