Mirrors Won't Budge
Madison, MS
My left and right mirrors on my '13 LC don't move at all. Is there a fuse I should check??
Thanks!
If the fuse info is not in your owners manual or on the fuse box lids in the ‘13, check the info on this site. There may be more than one fuse associated with mirrors. Any water inside?
Thanks!
Just to be sure...
When you push the slide switch above the large mirror adjustment rocker switch to the left, the left hand mirror glass will not move/adjust when you push the rocker switch, correct? And when you push the slide switch to the right, the right hand mirror glass will not move/adjust, correct? The slide switch is N OT in the middle position, correct?
Do your mirror housings rotate closed (mirror glass facing the body of the truck) when you push the mirror fold button? And then rotate back out to the use position when you push the mirror fold button again?
HTH
Just to be sure...
HTH
Yes! Housings close, no problem. Mirrors inside don't do anything when I move the slider left or right on the switch. I have a GX470, so I'm used to operating the mirrors accordingly.
