Hi,
My Cruiser is a '93 and she's throwing a code 28. I have FSM and Haynes manuals, but I'm a bit stumped, and any help would be appreciated.
Hayne's says code 28 is O2 sensors, and it says post-catalytic converter, which is a bit puzzling, since both O2 sensors are pre-catalytic converter (just on different cyl banks).
I've verified O2 sensors using the secondary method described in the Haynes manual, page 6-18 steps 18 & 19; running the engine at 2500 RPM and monitoring test points on the diagnostics block on the firewall of the truck. The test has you looking for 8 or more voltage fluctuations with an analog meter within 10 seconds, and mine was good, but I am unclear whether this test verifies both or just one of the O2 sensors.
I've also verified the O2 sensor heaters to be 6 Ohms (spec is 5 to 6.5 at 20C), and that there is 11.65 VDC on the heater circuit at the connector, so there is no problem there.
Haven't started poking around the ECM yet, maybe that's next, but I'm not sure where to start, and how to go about some of the checks, or which ones are most likely to be relevant. Here is where I could use some help.
Not due for smog check right now, but I'd like to get rid of the CEL anyway, and hopefully improve my MPG; currently averaging 13.7.
Thanks in advance for any help you can provide,
sb
sb
