Mayor Changes
I have a 1974 FJ43 Landcruiser with an F engine, 5 speed manual transmission (H150 Toyota), 4.111 differential and 31 x 10.5 tires, but I want a faster vehicle, so I am thinking on getting an 1FZ-FE engine. Do I have to make other changes in my transmission or differential? I might get the H151F transmission? Somebody told me that the fastest differential is the 3.700. What do I have to do ?
The engine doesn't really have anything to do with going faster. Your best bet is to get taller gear set in the diffs, switch to a tranny that has an overdrive, or larger tires.
a 72 fj43 would have had 4:10 gears orignaly.......but its hard to say whats in there now.
Please tell Where I can get a tranny or get me more information about this differential.
5-speed tranny will have the overdrive...nothing you can do there.
Stock gearing should be 4.10's....changing to 3.73's will be your only option for gearing for greater speeds....be warned tho, you may lower the engine rpm's enuf for most driving to kill your fuel mileage, all engines have a "sweet spot" in their powerband where mileage is maximized.
Your easiest/cheapest option will be installing 33x9.5 or 33x10.5 tires. IMO, do that first, see how you like it, then look at other changes.
I seriously doubt you have an H150 transmission mated to the F engine. It is possible, but the H55 is what most people would use for that engine. Look under the vehicle and see if the transmission case is steel or aluminum. The Al case is heavily ribbed and the steel case is smooth.
If you really have an H150 you're in good shape for a 1FZFE swap. Find an input shaft for an HDJ78 and bellhousing for an HDJ80 to make it fit. Or you can swap in an H151, it should bolt up to the transfer with no drama, but you get a 4.08 ratio first gear.
If you have an H55 you have to have a custom built bellhousing since Toyota never mated the tranny to that engine.
Dave
