- Joined
- Feb 24, 2010
- Threads
- 2,226
- Messages
- 2,226
Anaheim, Calif. —*MaxTrac Suspension is proud to announce its newest addition to their already extensive lineup of affordable signature series lift spindles. The new spindle fits the 2002-2008 Ram 2500/3500 2WD trucks, offering a full 3.5-inches of lift. Manufactured from extremely durable ductile iron and cast as a single piece, the spindle design offers a [...]
Anaheim, Calif. —*MaxTrac Suspension is proud to announce its newest addition to their already extensive lineup of affordable signature series lift spindles. The new spindle fits the 2002-2008 Ram 2500/3500 2WD trucks, offering a full 3.5-inches of lift. Manufactured from extremely durable ductile iron and cast as a single piece, the spindle design offers a larger neck and reinforced tie-rod bosses to handle larger, heavier off-road tires and wheels while maintaining O.E. specifications.
MaxTrac profiled the spindles to retain factory ride quality and handling. Track width is increased by 1-3/8 inches per side. Minimum 17-inch-diameter wheels with a maximum backspacing of 4.75 inches are required for single-wheel applications. Stock dually wheels will clear, and most tire sizes up to 35 inches tall should fit. MaxTrac recommends verifying tire and wheel fitment before mounting wheels and tires. MaxTrac finishes the spindles in a durable black e-coat to protect against rust and corrosion. Components are backed by MaxTrac’s limited lifetime warranty.
The spindles ship with DOT-approved braided steel brake lines, instructions, and all necessary hardware. The simple bolt-on design allows the spindles to be installed in less than 3 hours and requires no welding or cutting.
Link
Anaheim, Calif. —*MaxTrac Suspension is proud to announce its newest addition to their already extensive lineup of affordable signature series lift spindles. The new spindle fits the 2002-2008 Ram 2500/3500 2WD trucks, offering a full 3.5-inches of lift. Manufactured from extremely durable ductile iron and cast as a single piece, the spindle design offers a larger neck and reinforced tie-rod bosses to handle larger, heavier off-road tires and wheels while maintaining O.E. specifications.MaxTrac profiled the spindles to retain factory ride quality and handling. Track width is increased by 1-3/8 inches per side. Minimum 17-inch-diameter wheels with a maximum backspacing of 4.75 inches are required for single-wheel applications. Stock dually wheels will clear, and most tire sizes up to 35 inches tall should fit. MaxTrac recommends verifying tire and wheel fitment before mounting wheels and tires. MaxTrac finishes the spindles in a durable black e-coat to protect against rust and corrosion. Components are backed by MaxTrac’s limited lifetime warranty.
For more information, please contact MaxTrac Suspension, 4030 E. Leaverton Ct., Anaheim, CA 92807, 714-630-0363,www.maxtracsuspension.com,*sales@maxtracsuspension.com.
Link
