Call
@sleeoffroad and order their custom mounts that specifically fit two Maxtrax boards very nicely in front of the spare (tucked nicely behind the rear hatch).
See mine below:
Then...if you decide you want Rotopax too? Those can be mounted to the ladder via either Rotopax mounts, or in combination with a swingout From Slee that specifically is made to retain use of the ladder in conjunction with up to two, 4-gallon Rotopax.
**AND... If you are interested, I actually have all the rotopax mounts and special ladder-side Slee swing mentioned above for sale. It is an excellent solution, and the only reason I don’t use it is because I installed a big, second fuel tank.
PM if interested as using mine could save you a LOT of $. They do not come cheap buying new
Beyond that... Slee definitely makes a slick Maxtrax solution for the spare tire side...nice and tight against the vehicle. See below:
Black Maxtrax:
Right side shows how Maxtrax mounts...
If interested in Rotopax definitely consider ladder mounting...and like I say, my Slee-made ladder swingout is for sale (this is before I had the slee maxtrax mount)...
