saskdiesel said:Since I owned an 03 supercharged Xterra and have many Toyota's including my FJ40 I am not biased between these brands.
I have driven the new Xterra and compared it with the FJcruiser and for my money I would get the Nissan hands down.
I will not buy another vehicle that requires premium fuel and the Nissan has a sweet motor that runs on regular.
See ya at Cruise Moab!!
powderpig said:In the owners Manual it does require preminum and has some stiff warning on the use of lesser octane.
So saskdiesel the supercharged engine in the Xterra does not require preminum? I find that a interesting statement.
Toyota's line of engines using the same technology will all require preminum. This may change as more people complain, but I do not think this will happen. It is a balance between ecomany, power, and performance. If you check the 80 or 100 series threads on preminum vs regular, you may see what the cost is per year difference truly is. What I remember is that it is only a couple of hundred dollars difference on 15k miles a year.
I have had the good fortune to drive one of these FJ for the last couple of weeks, wheeling it and driving it with and with out a trailer. Here in the mountains of colorado we have towed trailers with about 2700 lbs up the mountain pass at 60mph (at speed limit), fuel ecomany so far has been around 14+ mpg(us gallon). On highway cruise control at 75+mph we get close to 18 mpg(with out a trailer). All this is with engine just over 1000 miles(break in for towing first). I do hope this provides some info that is lacking at this time. I will have more info to pass on, as time goes on. These little trucks wheel great just as they are. A lift will allow them to go even more places.
Catch you guys some where down the line at some event. later robbie![]()
I have no idea what your talking about..............powderpig said:I wrote a confusing post. I was refering to the FJ needing high octane fuel.
So then Sskdiesel, I refered to your post about you not getting a engine that needed fuel and made a statment about the Supercharger not needing high octane fuel. That is what I found interesting. So what info do I have wrong?
I see that you corrected yourself that you now have a non supercharged engine that does not require high octane fuel, but in the past you did have a supercharged engine that required high octane. The post i read did not have the info you just posted and I drew a inference from your post about the fuel.
My milage figures are on a 5 speed auto, with part time system. later robbie
warpedone said:A Rubicon will hold its value better than any of them.
