MASTER WINDOW SWITCH PROBLEM
Your switch is most likely fine. Sounds like you need to re-program your other 3 windows to then communicate back to the master window switch. It's a very common Toyota issue that usually happens when you have a dead battery or some other voltage related issue.
To reprogram the master window switch you need to go to each individual switch and set the top and bottom points. This is achieved with the ignition on, at the other three windows you use the switch and run the window all of the way up and wait ten seconds while holding in the switch in the full "up" position. Then let go and wait ten seconds. Do the same thing in the down position with the window all the way down. Remember to hold for ten seconds and then let go for ten seconds.
Once you program each individual switch you should now have control of that window with the auto feature from the direct window switch as well as the master window switch. Repeat this for all three windows and you should be good to go!
Thanks for this! My trailer lights bugged out my car and one switch was rolling down two windows! This fixed it. lol
