the 80 series master was/is original toyota part. will work as good if not better then your old unit. it is a direct bolt on operation. you may have to bend a brake line a little but no big deal, you may or may not have to adjust the rod between the master and the petal, i did not have to, it bolted right up and the amount of play was within spec. it will work perfect with original booster, i used my original 76 booster and its been a few years now and no problems.
good luck
frank
good luck
frank
