Master Cylinder Disappointment
SW Colorado
I disassembled the MC to clean and paint or powder coat. It looks fairly new (PO replaced), wasn't leaking, and the brakes worked fine before starting the frame-off last winter. Once cleaned and de-rusted I found the bottom of the cylinder is pitted. 😔
I have disks on all 4 corners so now I have to decide if I should replace or upgrade. Pretty sure an upgrade will cost less than a new 40 replacement, but I did find a reman 40 MC for $45.
Was hoping to start assembly in a few days. I just powder coated the pedal assembly yesterday.
Edit: I ordered an 80 MC.
I'm not sure what your budget allows, but a new 1" non abs disc/disc master cylinder cost me about $141 in April. I matched it with a 71-74 brake booster. The pair works quite well with a Wilwood proportioning valve.
