Mass air flow sensor harness
California
it looks like my wire harness for the mass air flow sensor has gone but and replacing it seems like a lot of work. The car keeps choking. Do you guys have any alternatives on how to fix this.
Is it the connector you are having issues with? If so they just replace the connector...if its available. Its easy to do.
Or the sensor itself...
Have you checked via the FSM if everything is in working order? What makes you suspect the harness?
Because when I start the car it chocks as soon as I hold the the end of the harness (connectors) a little tighter with my hand it stops
I had same issue. Call cruiserparts and they cut a good one out of a junk one $35 shipped. 30 mins to splice in and I took my time. Problem solved.
Just called them but their eastern time which means their closed right now, but thanks I just hope that solves my problem if it turns out to be the harness I'm in a big trouble
Seems most people don't like to cut the wire harness up when parting out. Maybe try posting in the "Wanted" part of classifieds.
