Marlin Crawler's 8th Annual Maintenance May is here!!
Fresno CA
Website
www.marlincrawler.com
Our 8th Annual Maintenance May has begun!!
Fix leaks and refresh your bearings and seals before the wheel'n season resumes!
10% off All Front Axle Service & Knuckle Kits
10% off All Front Axle Wheel Bearing Kits
10% off All Rear Axle Service Kits
10% off All Available Transmission Rebuild Kits
10% off Transfer Case Rebuild Kits
10% off All NINJA R&P Setup Kits
10% off All Yukon R&P Setup Kits
10% off 27 & 30-spline Front Chromoly Marfield Axles!
10% off Rear Chromoly Axles!
10% off Low Profile Drain Plug with steel gasket
10% off High Quality CNC Machined Spindle Nut Kit
10% off E-Locker Diff Gasket
10% off Land Cruiser Rear Differential Cover Gasket
10% off Hilux & FJ80 Knuckle Stud Kit
10% off 8mm Hub Stud Kit
Stay tuned for Week Two!
Subscribe to our Newsletter to stay updated @ MarlinCrawler.com/newsletter
This week we added 5 products to the sale bringing the sale count to over 70 items!
10% OFF Mechanical to Digital Vehicle Speed Sensor
10% OFF Low Profile Drain Plug with aluminum gasket
10% OFF Heavy Duty Gear Drive Shift Spring, Tacoma T/Case
10% OFF Heavy Duty Gear Drive Shift Spring, Hilux T/Case
10% OFF Heavy Duty Gear Drive Shift Spring, Land Cruiser T/Case
Stay tuned for Week Three!
We've added 18 locker specials including FREE Extended Warranty programs valued at $65 each!!
10% OFF all Drop-in Automatic Spartan Lockers!
FREE Extended Service upgrade ($65 value) on all High Strength Automatic Grizzly Lockers!
FREE Extended Service upgrade ($65 value) on all Air-operated and Selectable Zip Lockers!
Stay tuned for our FINAL WEEK!
For our final week of Maintenance May, we've added some USA-made armor to protect your maintenance investment!
10% OFF 60" weld-on Rock Sliders
Applications:
  • 1979-1995 Hilux Shortbed
  • 1984-2002 4Runners
  • 1995-2004 Tacoma Single Cab
10% OFF 70" weld-on Rock Sliders
Applications:
  • 1979-1988 Hilux Longbed
  • 1984-1988 Hilux XtraCab
10% OFF 80" weld-on Rock Sliders
Applications:
  • 1989-95 Hilux XtraCab
  • 1995+ Tacoma Access Cab
10% OFF Interior Roll Cage Kit
Applications:
  • 1979-1995 Pickup
  • 1984-1995 Pickup XtraCab
  • 1984-1996 4Runner
This takes the total to nearly 100 products on sale for only 1 more week! Click here to view the full list:
MarlinCrawler.com/Maintenance-May
