marlin crawler hight steer
will that hysteer setup fit my 77 landcruiser. Trailgear has the same setup and the guy told me it would not fit. Also looking into the double arm steering from man-e-fre and keeping the tie rod ends the same. any help would be great.
The 77 has the small pattern knuckles so the high steer will not fit. I think Luke Porter at 4x4 labs has a set up that will work for you.
If I were you, though, I would swap in FJ60 or mini-truck knuckles/spindles/birfs/hubs/brakes and go to a more standard set up.
x2, not that difficult and a TON of info on the swap. Its only a few hundered for ^ and worth it.
