Mark's Adapters ABS relocation ring
Beaverton, Oregon
Has anyone had a problem with their brakes after installing Mark's Adapters ABS relocation ring with their part time 4 WD Kit?
I seemed to have developed a death wobble and was wondering if this might be the cause if it was dirty or became misaligned. My ABS light is off.
This wobble only seems to happen under braking around 50 mph on flat ground (sometimes) and on descents of steep hills. My LC also seems to pull to the right when hard stopping sometimes too. The problem is not consistent. This might be a seized caliper piston as well. Further investigation is needed.
I am running out of things to check on the suspension. All the usual suspects have been checked........tie rod ends, panhard bar, balance tires, wheel bearings, trunion
Thanks,
Bart
No experience of the Marks kit but, I very much doubt it has anything to do with the ABS ring. If the sensor was 'out of touch' with the ring you would get a light and a code would be thrown. If the ABS was acting up you would soon know about it as the brake pedal would be pushing back at you and this would be only under very hard braking.
Death wobble could be, sticking piston in one (or more) of the callipers heating up and distorting the disc or, the upper and lower trunnion's has the incorrect pre load. You do mention them but were the races removed and inspected? As the races only move through a small arc they wear only in one place, occasionally the races move and you get the DW.
What about the damper resistance, might be worth checking. Often find these things 'look' OK with no leaks but removing them exposes no resistance in one direction etc.
Pull a brake pad on one side and slip a thin piece of plate or wood, have someone slowly press the pedal and see if the piston move out smoothly, they do not have to move at exactly the same pace but similar amount of movement is sufficient, if you find one moving significantly more than the other then have you assistant to stop and then try holding back the piston that is moving easily, then get the assistant to start pressing again. I would do this on ALL of the pistons front and rear. Sticking pistons is normally due to some corrosion in the piston/calliper body. Which in turn is caused by water sitting in the calliper of the outer boots have failed.
regards
Dave
Thanks. I am really grasping at straws here. All 4 OEM calipers, pads, lines, booster and rotors are less than 8 months old. I will check them though.
