Manually locking an e-locker
Seattle, WA
I tried searching and cant find what I am looking for. My buddies '94 FZJ80's rear locker is not working. The light just flashes on the dash and it doesn't engage. The front works fine. It is probably a bad motor or something like that. Anyway, we are leaving for a wheeling trip tomorrow morning and I don't have time to do any serious trouble shooting on his rig.
So, my question is, how specifically do I manually lock his rear locker? Please be as specific as you can, because I am not very familiar with elockers. Thanks a bunch!
Joe
You don't manually lock an e-locker. I can't think of a single way to do it.
His is just sticky. I bet if he leves it selected 'on' it'll engage when he needs it on the trail. They need to be used to keep working.
Are you sure? I could have sworn I read that you can manually engage the elockers. Something about taking the motor off and using a screw driver to push a pin in or something. Also, on the pros and cons list it says one of the pros of the elocker vs. the air locker is that you can manually engage it in a pinch... https://forum.ih8mud.com/79-95-toyota-truck-tech/108390-arb-vs-toy-locker.html
If not, than I have made a mistake and I will have to do some trouble shooting tonight. Thanks, Joe
The easiest way that I can think of is to remove the 3 bolt cover and the big gear out of the actuator, jack up the right rear, rock the tire and push/pry on the shift shaft until fully locked, then put the gear and cover back. Be sure to unplug the actuator, the slide switches probably wont be lined up properly and will put power to the motor possably burning it up.
The other way is to remove the motor cover, turn the armature until locked. This sounds simpler, but there is a higher risk of damage to unavailable parts and if the gear and/or output side is stuck this method wont work.
I haven't done it, on the trail I had the rear stick locked once, drove it home and then to work so I could repair it correctly. No internal parts are available, so care needs to be taken when working on them, a replacement actuator is $$$$, IIRC ~$600. The rear is relatively easy to clean/grease, takes me maybe 1 hr.
