I have 97 cruiser with poverty package. When boight it last year on my way home I noticed the drivers seatback was stuck. No biggie it was ok where it was set but 2 days ago it managed to slip back a notch or 2 when i was leaning back trying to get something out of my pocket. I have never taken a seat apart has anyone run into this issue. I am assuming it is some kind of return spring issue.
If it was me, I would start by removing the seat. This allows easy access and it's only 4 14mm bolts. Next, remove the plastic side covers (phillips screws and clips that can be seen by flipping the seat upside down) to see the hinge assembly. From what I remember the entire hing sits outboard of the fabric. everything for the locking mechanism is very large and you should be able to find the problem by jiggling the seatback back and forth and pulling on the release lever. It probably is a return spring or something jamming it that can be repaired quickly. It'll probably take less than 10 minutes. I wish I knew of a common issue, but let us know what you find.
