Manual hub swap
New Hampshire
I have done some research on people's opinions on switching an 80 to Manual Frt locking hubs. I took Spikes advise and removed the Driveshaft and the handling wasn't as bad as I had thought. I wasn't however able to find the info on the conversion. I had heard that I could use the hubs off an early model toyota pickup, but do not know what years and what kind of a job that will be for a do it yourselfer. Trying to save as much money as possible. Some direction would be greatly appreciated.
Derek
Make sure you are doing the conversion for the right reasons, if it is for economy or something like that it is a waste of your money, you will not make it up in economy.
I may have a similar concern so am posting this on this thread (instead of creating a new one):
I was recently "sold" into purchasing an AVS manual locking hubs (not aisin for economic reasons). Considering that I use my LC as DD only and not for any off-roading, the less wear and tear on the front-driveshafts by moving from full-time 4WD to 2WD makes sense to me.
However, when the seller installed the hubs, he said that I would have to always set the Center Diff Lock switch to ON (with the tcase lever set at HIGH) and the hubs set to UNLOCK. If I need to go back to 4WD, I just turn off the CDL and manually lock the hubs.
Is the above CDL setting correct to make a full-time 4WD HDJ81 act like a 2WD? What is the impact of always driving with the CDL ON?
Thanks,
Thanks,
the reason you have to have the CDL on is because you are still in AWD, with the kit done correctly you will be in 2wd with the CDL on and in 4wd with the CDL engaged and the hubs locked in, with what you have the front drive line and axles still always turn they are just not under a load.
eldgenb,
thanks. but still need further clarification (guess I can be considered a off-road dummy - read the "diff for dummies" post twice and still have some questions):
1. Stock LC80 with no locking hubs is a full-time 4WD, right?
2. With hubs UNLOCK and CDL ON, am in AWD (the 4 wheels still have individual drive going through them) but am in 2WD mode (the rear driveshafts are the only ones with load). Similar to a Rear Wheel Drive configuration?
3. With hubs LOCK and CDL OFF, the LC is back to Item 1: full-time - 4WD, right?
4. Can you LOCK the hubs and still turn ON CDL? What will this do?
And for my DD needs, am ok sticking with Item 2, right? Being in 2WD should not put wear and tear on the front driveshafts? Or should I just remove these hubs and go stock?
eldgenb,
#1 Stock LC80 with no locking hub is AWD(power can be sent to either front or rear axle independently)
#2 With CDL Locked and hubs unlocked you are in 4wd(power is sent equal to all four, with front hubs unlocked front end does not use the power sent to it but front drive line and axle still spin just not under load)
#3 With hubs locked and CDL unlocked you are stock AWD#1
#4Locked hubs with CDL engaged is 4wd meaning both front and rear differentials get the same amout of rotations or power front and rear. More like a chevy or Domestic would be.
the AWD means that when one wheel slips the others are supposed to compensate, when the CDL is engaged the others do not compensate for the lack of traction they just go the same speed no matter what..
on my 1990, the seller/mechanic just removed the wheel, then removed the "stock hub" - (dont know what to term it), then installed the AVM hubs, then put in the center cover of the AVM hub. Then he installed the wheel, removed the jack, hit the CDL and power on the LC. Then we droved away. So far, no issues
btw, I have the AVM SUPER MANUAL - 500 Series (http://www.avm.com.br/products4.htm).
How come the steps done to install the AVM hubs on the JDM 1990 are totally different from what was described in http://www.sleeoffroad.com/technical...conversion.htm?
Should I be worried? Or different hubs require different setup?
Sounds like you still need to install the part-time 4wd kit to the t-case. Your not really gaining anything until you stop sending power to the front axle.
You need to pull out the pinion (spider?) gears from the t-case and install the solid unit pictured in the kit ....
(pics stolen from links above)
Once/if you go to the front free wheeling hubs the ABS will not work in normal driving (on road) situations unless the you select H4 and then lock the centre diff
another good point... although I believe all you need to do is lock the wheel hubs rather than the cdl (in high range)
to clarify dereks' rig is non abs as well as podiev's (please correct me if I'm wrong)
non-abs.
to all - thanks for info on the hub setup. I'll probably just leave the setup as is for now: hubs UNLOCK and CDL ON. At least there is some reduction (albeit minimal) in the wear and tear of the front driveshafts since there is not much load.
The part-time 4WD kit requires big bucks and requires some mechanical work. I would have to find a good LC mechanic in the Philippines that has done this conversion before.
Thanks for Info
Thanks to all. Sounds to me that it is more trouble than what it is worth for the moderate wheeling I want to do. I think I will just lock my rear and go for it. Thanks again guys.
Derek
Hey all I have a similar question
Hey I see you guys chatting about converting an FJ80 to manual hubs, do you know if this conversion can be done with stock toyota parts from other axles? if so what should I be looking for? or do you have to go with at $500 AVM kit? I dont have an FJ80, but I bought a front axle out from a 1995 FJ80(HP, Elocker), I want to put it under my 85 and do a 3 link with it, but I would also like it if it had manual hubs instead of the entire front driveline always spinning when I am not wheeling..
Any help?
Thanks!
Jason(new to Ih8Mud)
You would also need to drop the front drive shaft for this not to tear up stuff, then use a center diff lock switch to lock the center. You will still have parts turning in the front, the bushing in the hubs will wear soon(not designed to have constant movement through them),if you do not either put in a center diff kit or drop the front drive line when you want rear wheel drive. It is not a good idea to have the parts in front turning like this. You do not save any fuel unless you do not have the front dif and parts turning. later robbie
Putting the hubs in and unlocking them simply shows you how the vehicle handles. As Robbie points out it will not reduce wear much, nor will it save much gas (unless you take further steps). I played with all this and concluded that in NE, the loss of handling is not worth the gain in fuel, for me at least. Want to buy some Asin hubs?
Yeah this is going under my 85 4Runner, I already have a TRD locking rear, and want one in the front, so I have no issues to worry about when it comes to a CDL, I would just prefer that the birf/axles/front driveshaft not spin while I am driving to the trails, as this is not a trailer'ed truck, less wear and tear on the birfs, and less drag as well.
