If you are desmogged, and still want a functional HAC, you can repurpose one of the electrical VSV's to that end. The concept is very simple - install an on/off switch on the dash, one side connected to a ignition hot. The other side goes to the VSV. The VSV for it's part needs a source of vacuum - I pulled from the three-prong deleo on the intake manifold. When you turn on the dash switch, the VSV opens, and vacuum is applied to the secondary advance on the distributor. The VSV I used has two vacuum ports - E & F. F is the port for the vacuum source, and E is the port that's connected to the secondary advance on the dizzy. Here are some pics. In hindsight, it would be better to use a lighted dash switch, as it's easy to forget when it's turned on.
