Why isn't there a mounting ear at the end of the manifold so you can tighten it up on my 76.
I see what your saying on the alignment. I'm going to try and shift it to the right a hair! ThxNah. My 75" is like that. In the rear just past cylinder #6 there is an engine hoisting point in that hole. I would be more worried about a potential gasket misalignment there on the #1 exhaust port.
Mark, just to be clear, would it be correct to say my 74 was the last year of the one piece exhaust manifolds and no one piece manifold had ears on the outer ends?Yep, your 74 F.5 head, with it’s upgraded rocker oiling, should have the extra exhaust bolt hole....still, it’s the same as a 2F head. The photo above is a 68 to 74 exhaust manifold on a 2F head.
I don't think so. My Jan of 75' truck has the same manifolds and I believe them to be original to the truck. As far as one piece exhaust manifolds having only 1 attachment point, you may be correct. I never realized before that the 3 piece design utilized those threaded holes on the head, but now that I do I may have to pull one from my pile and swap it over when I go EFI. Thanks for pointing that out.Mark, just to be clear, would it be correct to say my 74 was the last year of the one piece exhaust manifolds and no one piece manifold had ears on the outer ends?
Remflex states that the user can cut away any portion of the gasket that's excess... There is no metal layer, it's all graphite.You have to remember, early 70s were transition years, air emission regulations were changing very quickly and for many manufacturers, tooling changes barely kept up. I imagine Toyota was just cleaning out it’s parts bin....they had the new head design but a boat load of old manifolds to use up.
I believe that yes, the F manifold installed on the F.5 or early 2F is original....but it IS an F manifold, for a 68 to 74.
In the picture above, I think I would have gotten the F manifold gasket....then you wouldn’t have the ‘ear’ flapping in the breeze (lol).
