Manhattan/Topeka Mechanic
My advice would be to give the engine and chassis a good cleaning with a power washer, get all the grease and oil off of it. Drive it for a week or so and then if you are in the Topeka area I would be happy to look at it with you. This will allow any leaks time to present themselves after you've cleaned all the old gunk off. How does it run/drive ?
It drives ok. It starts etc. I think one of the brakes is stuck. It seems to take a lot to get it going. More curious what on it is orginal, not orginal etc. Its a 81 rhd, power steering with a/c.
Easy enough to check those brakes if you have a floor jack and some stands. Just take up one axle at a time and try rotating each wheel. If you don't have a jack drive it around and see if it pulls when you let off the gas. Also, if one is stuck or you have a bad wheel bearing the wheel sometimes will heat up quite a bit more than the other wheels.
