Makita 18V Brushless Impact Driver is More Powerful and More Compact
La Mirada, CA Makita has released the new 18V LXT® Lithium-Ion Brushless Quick-Shift Mode™ 3-Speed Impact Driver, model XDT09M. It is the most powerful and most compact impact driver ever made by Makita.
It’s part of Makita’s expanding 18V Lithium-Ion series, the world’s largest cordless tool line-up powered by an 18V Lithium-Ion slide-style battery. Makita 18V Lithium-Ion batteries have the fastest charge times in their categories, so they spend more time working and less time sitting on the charger.
“Makita has a legacy of innovation in cordless impact drivers, and the XDT09M sets new standards,” said Adam Livingston, Makita Product Manager, Cordless Tools. “The XDT09M has more torque and more speed than previous models, yet it has more features and the most compact size in the 18 volt category. For contractors, the XDT09M is a total fastening solution.”
Quick-Shift Mode™
Precision fastening applications often require the user to stop or slow down the impact driver just prior to driving the screw into place to ensure there is no damage to the fastener or work piece. Quick-Shift Mode™ is an automatic electronic controller that downshifts and reduces rotation and impact speed prior to driving the screw into place. It is engineered to minimize screw thread stripping, screw breakage and damage to work.
Quick-Shift Mode™ can be engaged with a push of a button at the base of the handle. When the driving process begins, the impact driver starts driving at 3rd speed (3,600 RPM). As the screw nears the fastened position, Quick-Shift Mode™ is automatically engaged and downshifts to 2nd Speed (2,100 RPM).
Precision Features for Fastening
The Makita-built BL™ Brushless Motor delivers a full 1,550 in.lbs. of Max Torque in the 3rdspeed setting. The 3-speed power selection switch (0-1,100/0-2,100/0-3,600 RPM and 0-1,100/0-2,600/0-3,800 IPM) provides the user with precise fastening control for a range of applications, from cabinet screws to lag bolts.
The XDT09M weighs only 3.3 lbs. with the 4.0Ah battery. With a length of only 4-3/4″, it is 3/8″ more compact than the Makita XDT06 and the most compact in its category. Other features include a 3-stage battery power indicator and Makita’s Extreme Protection Technology (XPT), an interior seal inside the tool engineered for improved water and dust resistance for use in harsh jobsite conditions.
Similar to all Makita impact drivers, the anvil impact mechanism in the XDT09M is engineered using the best raw materials with the highest quality steel and unique heat hardening process for maximum fastening and driving power.
Communication Technology Protects Battery and Tool
For improved tool performance and extended battery life, Makita created Star Protection Computer Controls™. Star Protection is communication technology that allows the Star Protection-equipped tool and battery to exchange data in real time and monitor conditions during use to protect against overloading, over-discharging and overheating. For increased versatility, the tool can also be powered by Makita 18V LXT® and Compact Lithium-Ion batteries with the star symbol on the battery indicating Star Protection inside.
Specifications
XDT09M
XDT09Z
Hex shank
¼”
¼”​
No load speed
0-1,100/0-2,100/0-3,600 RPM​
Impacts per minute
0-1,100/0-2,600/0-3,800 IPM​
Max. Torque
0-1,550 in.lbs.
0-1,550 in.lbs.​
Battery
18V LXT® Lithium-Ion​
Overall length
4-3/4″
4-3/4″​
Net Weight
3.3 lbs.
(with battery)
3.3 lbs.
(wiith battery, sold separately)​
Includes
Tool, 2 ea. 18V LXT® Lithium-Ion Batteries, Rapid Optimum Charger, Tool Belt Clip, Tool Case
Tool only
About Makita U.S.A.
Makita® is a worldwide manufacturer of industrial quality power tools and outdoor power equipment, and offers a wide range of industrial accessories. Makita utilizes leading-edge technology and innovation to engineer tools that are more compact with less weight yet deliver industrial power and results. Makita’s extensive line of cordless lithium-ion tools includes 18V LXT® Brushless Lithium-Ion, 18V Compact Lithium-Ion, and 12V max Lithium-Ion. Other best-in-class products include rotary and demolition hammers and saws equipped with Anti-Vibration Technology (AVT®), MM4® 4-Stroke engine power equipment, Super Joint System – SJS® grinders, miter saws engineered with Deep and Exact Cutting Technology (DXT®), Impact GOLD®, the New Gold Standard in Impact Driving, and more. Makita U.S.A., Inc. is located in La Mirada, California, and operates an extensive distribution network located throughout the U.S. For more information, call 800/4-MAKITA (800/462-5482) or go to makitatools.com. Follow Makita:facebook.com/makitatoolspage, twitter.com/makitatools, youtube.com/makitapowertools, instagram.com/makitatools.
Continue reading...
