Making really improved parts out of totally generic bicycle crap...
Patineto
"Clueless" fourwheel rabbit
Minneapolis, mn
Website
patineto.smugmug.com
A very basic example..
We all know that flexion, friction, wrong angles will rob you valuable clearance/feel with the rims and you brakes.
Specialized M4 cyclocross racer..
The rear routing was a absolute joke, so vague, weak, unreliable, tons of drag, brake springs at full tension just to overcome, the brake cable will seat on the top tube like a lazy snake when is suppose to be as tune as a guitar string..
Present you, Stupid trek water bottle for the Y bikes, extruded piece but of good quality.
Tools 4 1/2" grinder with a flapper wheel, some old drill tits and a drill.
Work so much better, Have the spring tension of the brake string, snappy accion, pads 2mm away from rims, just perfect.
I need a lot of help stopping my ChubbyA^^
Step two, efficient Stem cable routing.
Shimano front derailleur adapter mounts, Miracle same diameter as the stem...
Different approach.
This was actually a "Rolla magic" type clone.
Very tight curves, but very smooth, made it about 12 years zero adjustment zero failures.
Many more to come..
