Making adjustable control arm
Hope, maine
I am going to make new or remake the old control arm to be adjustable and wondering do I start with factory length and make so it can get bigger or do I start with 3" or so of adjustment and make factory length in the middle if the adjustment thanks
I would make them maybe 1/2 inch shorter than stock but really the only adjustment that you would need is longer. unless your making
(and no judgement if you are) a low rider you wouldn't need the arms shorter than stock.
Hahaha I do like toyota lowrider trucks but yes this going up.
Thanks for the info
Maybe I'm missing something, but I don't see where ride height would determine arm length. Ideally the axle is centered when the suspension is compressed, no? Which is how it is stock. Very minor adjustments might be advantageous depending on setup.
I would allow for adjustment in either direction, favoring whichever direction you think you need the most.
I am not super knowledgeable about this but I want to control pinion angle in relation tcase, this will change under compression bit there is s sweet spot it will spend most of its time.
making the arms adjustable will allow the pinion angle be changed. when the truck gets lifted the pinion angle and t-case angles will increase and there is a possibility for a drive line vibration due to the angles. lengthening the upper arms will lower the the angle on the pinion side of the shaft and can elimiminate driveline vibes.
the control arms do center the axle but the panhard bar is more responsible for that and if the lift is high enough then that will need to be lengthened as well.
The front and rear u-joint angles should be equal, changing only the pinion angle is a recipe for issues, unless you go radical and reverse the rear angle entirely (as I have done). In my case, yes, adjustable arms are required. They are also useful for gaining a fraction of an inch in front or behind the axle when using certain wheel/tire combinations. For most applications that's all you'd ever need.
The panhard is responsible for positioning the axle side to side. The control arms position the axle front to back. I also have an adjustable panhard, but it's set to the factory length. The axle is offset at ride height, but moves back to center when stuffed. Making it longer forces the tires into the quarter on one side and the frame on the other when cycling the suspension.
In any case, yes, there are reasons for adjustable hardware, but lowering the truck isn't one of them.
