Major Steering fluid leak
Toronto, Ontario
Thought i'd relate my morning experience.
Cold start in my driveway, started scraping off some frost and what do I see?
A giant puddle forming by front DS tire. I rush to shut off, stick my finger in the liquid, it's a nice red coloured oil.
My first thought was Tranny but a quick check of power steering fluid reservoir shows it is empty.
Quick look down by bottom of rad looks like power steering line leak. Since it's winter in Canada and too cold to work in my driveway I fill up reservoir and off to my local Toyota dealer (trusted dealer for years).
I'm thinking a quick hose connection needs tightening but to my shock when the mechanic quotes me over $1600.
He tells me leaking hose but everything else (steering cooler) is rusted to crap and wants to replace everything properly. I looked and confirmed his observation. Over $900 (Canadian$) in parts and 6-7 hrs labour required.
A quick call to Dan once again saves me hundreds of dollars in parts.
I'm still in shock that the overlooked steering system would creat such a huge repair bill.
Any "system" not properly maintained and looked after will always cost you more in the end to either repair it or replace it.
In regards of the steering system, and OEM gear box alone will cost you upwards of $2000.
After a long period of time, most systems and their components fail due to a number of issues. That's just engineering 101.
So the cooler had water sitting in a line, it froze and split.........is that what happend?.........that sucks:frown:
I had a leak from the lower pump hose connection....just an O ring, but I never thought of flushing the whole system, prolly a goood idea.
I've owned since last April and I've been doing the turkey baster thing every couple of weeks to replace the fluid.
The original fluid was very dark so the PO never had it changed. That, in addition to northern road salt did the lines no justice.
Still worth every penny to repair, and now I don't have to worry for another 12 years.
For those of us who live in areas where they use salt, this is going to be a common problem as the truck ages.
The PS cooler is just a paper-clip shaped bit of tubing that traverses under the condenser in front of the crossmember. To get the PS fluid there, a hard line crosses over the top of the crossmember and is held in place by some tie downs attached to the frame. Over time, dirt and salt will build up around these connections since they're not readily accessible when washing the truck, so the salt will slowly eat away at the PS cooler at these points. Eventually, you have a leak.
Water should never be in the PS system, so it was not a freezing issue.
Why not mount a second tranny cooler, and get some generic power steering hose? Then the cooler gets out from under the truck, and you can increase the cooling capacity. I have seen nice small tranny coolers for $75-$100. Others have pulled Toyota tranny coolers from a yard and used that to cool the PS fluid. Orange45 on IH8MUD at one time had these great tranny coolers that could easily bolt up under the grill with a bit of enginuity. I did this in my FJ40 and it worked great to cool my Saginaw conversion.
The stock PS cooler (IMHO) is just a piece of tube and mounted in a bad place. I think this could be fixed for much less and better.
Just askin': the PS fluid reservoir fills close to the top? I opened mine today for a look see and fluid level is way down the bottom. Poured some Dex III ATF but only half way until I know what I'm doing :doh: To the top or ??
Doesn't your cap have a little dipstick in it that indicates the correct levels when cold/hot??
