major starter problem
Santa Barbara
I took my 40 on the first real drive today up into the mountains. Somehow the key did not go back from start to ignition and I ran about 30 miles with the starter engaged. :whoops: Well after I shut it down at the top to take in the view the moter spooled down with a nasty sounding noise and there was smoke and a bad smell coming from the motor after I investigated under the hood. I really thought the motor seized miles away from any phone or people. I looked at the starter which was the source of the smoke and realized what had happended. There wasnt even a click when trying to start it at this point. I push started and was able to drive back without problems except for that nasty motor burning smell. I could not disengage the starter from the flywheel and had no tools to replace it. Other than replacing the starter, is there anyting else that could of fried? I assume that the starter just acted as a generator for a while and sent current straight to the battery? Any suggestions would be appreciated.
Don't beat yourself up too much. My father-in-law's '71 has the same issue with the key. If you don't turn it back a little bit, you can here a slight noise from the starter. That stuff happens. You probably should have the battery checked, but it might be just fine and need a charge. Also, depending on the year of your rig, you might want to upgrade to the later model starter. Not sure what year it is, but it makes a difference. Good luck.
Please post up some pictures of the starter once you pull it. I am insterested to see what it looks like on the inside. Your flywheel teeth may be toast also. This is the perfect time to replace it with a gear reduction unit from a 60 series.
ok, so it is good to know that this would probably not damage anything else. The flywheel is fine, just a little polished up where the starter engages. Unfortunately the starter was BRAND new. I will post some pics once I have time to work on the truck and pull it out
i doubt a return would work. I pulled it this morning and 2/3 or the teeth are sheared off the drive gear, and the paint is all bubbled. This thing probably got super hot before it seized. The casing on the wire is melted off also. I might be able to play it off that the solnoid never retracted due to the starter, not my key being turned since it is brand new
